Curtain Wall Scheme Grid Reverts to Original Grid Pattern When Boundary is Edited
Aiden
Hi, apologies if this has already been answered.
In Archicad 23, when I edit a curtain wall which has been created using the plane input method and boundary and has had its scheme grids modified through the curtain wall edit mode, when the boundary is changed through the curtain wall edit mode the scheme grids revert to the original scheme grid pattern. This means the scheme grid modifications need to be redone whenever the boundary is modified.
Is there a way to edit the curtain wall boundary without affecting the positions of the scheme grids?
Thanks.
0 REPLIES 0
