Curtain wall problem
Hi, I was trying to place a curtain wall and set the distinct panel to be a "Corner Panel" from the drop down menu. But when placed the panel is not centered between the frames, see picture. I tried to set different values to frames and to panels but the alignment is still wrong.
thanks
1 REPLY 1
Every now and then I got this same issue, but it usually happens with doors in the curtainwall. The 3D view looks ok but then in the floor plan is displaced. I'd like to know how to fix that too.
