Read more
Curved text
Is it possible to do curved text in AC 9?
22 REPLIES 22
yes
Hi, Mr. Jepsen. Thkx for Ur reply, but more detailed explanations on how to do curved text would be much appreciated.
Thanks again.
I didn't say there was a GOOD way.
http://www.objectsonline.com/arc/default.tpl
Iniversal 3D Text. $20.00
You can also import the text from Word or other programs that can make curved text better and import it as an image.
If its just a few words you could make individual letters and rotate them to match your curve. If you do this I suggest you make one letter and use the multiply-rotate-distribute feature to get a uniform curve and then edit each letter. Its much faster.
Do U mean I have to buy an add-ons?
Objects Online also has an add-on for $15.00 that is called Text Radial 3D.
not sure if this is what you're after
http://perso.wanadoo.fr/archilib.od/
but it is free
bill
There are so many interpretations of "curved text" (half a dozen in my mind anyway), that perhaps you could show an image of what you want to produce?
Karl
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.7, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
giza
hi don't know if this would help but i downloaded this from www.archicado.com
giza
Gezim Radoniqi | Architect | BIM Manager @ 4MGroup
ArchiCAD user since version 6
AMD Ryzen 3950X CPU, 64 GB RAM, NVidia RTX 3060 12GB
Karl
Thanks for Ur helps.
For example I must indicate the sea high water level on a site plan. I want the text to follow the path of a spline.
