Curving a roof
derekjackson
I've inherited a model which has a curved building on - the roof is contructed as a complex wall, but seems quite facetted - its curve isn't as smooth as the wall it sits on (a separate element).
Is there a way of simply increasing the resolution of the curved roof, or will I have to recreate it? (Bit of a hassle to do).
I've tried changing magic wand settings, but I'm guessing they only affect elements created after that point?
Thanks,
Derek
1 REPLY 1
Dwight
Correct!
Assuming that you mean "Complex profile" wall, capture the section of the complex profile to redo the curved element.
If the element is a geometric curve, draw it with the curved wall tool, if an irregular curve, use the magic wand setting to control the smoothness.
Dwight Atkinson
