Deleting Xref Layers ? removing missing library objects?
really two issues.
I have deleted the xref in the drawing, nothing showing in the manager, but, the layers still appear in the layer list. tried to highlight delete, but delete is not an option. -----how can i clean this up?
i have an old stray ac11 object in the file, i think i deleted it but how can i make sure i stop getting the error when opening the file?
David Maudlin
Some have use the Attribute Manager to delete these layers.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I am using AC15.
the item is Tap 11 (1) and I can not find a way to delete it. even find it for that matter. Once I realized I had pasted it in (inside a group) from another file, i thought I had deleted it.
ANY help would be great!
THANKS!
If your library loading report is saying you have a missing object then you haven't deleted it from your model but you have deleted it from your library.
Use find and select to look for all obbjects with that name.
Make sure you turn all layers on and look in all storeys.
If it is not the library loading report message you are talking about can you show us a screen capture of it?
