Depth marks on facade;
How can i load depth marks on facade?
Ecample:
17 REPLIES 17
What exactly do you mean?
Your image is not showing.
Marks that are showing distances on facade, For example closer wall is +/-0,00 and further wall is +1,20.
Did
You can turn on the 'Marked Distance Area' in the section/elevation settings if that is what you mean.
It will automatically adjust the pen thickness or you can control by setting a uniform pen.
It won't show any marks in elevation - I still not sure what you mean by that.
Lingwisyer
Guru
Like a Level Dimension for elevations and sections?
I want to show in elevation depth marks, to put marks on walls, wall that is closer is for example +/- 0,00 and wall that is further is +1,10 etc, as I showed in picture that i posted.
Is it possible?
Thank you in advance
Erwin Edel
Not that I know off.
I don't recall ever needing to add those dimensions to an elevation though. The person on the construction site who needs to know that dimension, will be looking at a floorplan, for example.
p.s.
you can upload images to attach them to your post, linked images from other sites don't seem to want to play nice with the forum.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
How can I upload picture directly to show you?
Lingwisyer
Guru
enc.
When you create or reply to a post you will find an 'Upload attachment' tab below.
You can attach saved files but only in certain formats and there is a maximum size.
I have never had any problems with just doing a screen capture, saving that as a JPG file and then attaching it.
