Detail Tool Plan Marker
I'm having a hard time figuring out how to show the detail marker boundary (using the rounded rectangle marker polygon) at an angle. It seems that if I rotate the tool, or stretch the boundary, or change the boundary to a polygon, that the "clipping path" always draws lines parallel with the original grid lines. This also true if I rotate the plan view. Anyone else experiencing this problem?
Thanks in advance!
David Shorter
ArchiCAD 15 introduces a new control into the detail marker see attached
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Perfect, thank you!
JaredBanks
Mentor
David,
Cool. You should add that to the list of undocumented v15 changes (I presume that's not advertised anywhere).
http://archicad-talk.graphisoft.com/viewtopic.php?t=36880
Jared Banks, AIA
Shoegnome Architects
