Disappearing stairs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2019-11-27
05:16 PM
‎2023-05-19
10:32 PM
Gordana Radonic
I can see them fine in the project map or the view map which i place later in my layouts.
So the stairs are invisible when displaying my floor plans in layouts, but not when displaying my view maps
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-29 02:26 AM
If it looks correct, change it to something else and then change it back.
I remember reading a post that there was trouble with reno filters.
Here was the post...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-27 11:48 PM
There is allways a good reason
Do you use archicad stairs from a previous version ? Do you do a library migration ?
I invite you to built on of them with your last archicad to check it.
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-28 12:41 PM
When i try the same in a new file everything works just fine.
What setting could be preventing stairs from not showing in the layout? but everywhere else
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-28 01:28 PM
Do you update your archicad or is it already a 3000 version ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-28 02:14 PM
You think this could be a bug?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-28 02:33 PM
Can you check and probably delete and remake your library links ?
Telling it's a bug mean we are sure there is no other reason. We can tell it cause there are so much informations we don't have to conclude as fast as you wish.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-11-29 04:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2019-12-05 09:26 AM
Barry wrote:this worked!!!! thank you very much Barry, now stairs appear on the layouts also. case closed
Just out of interest, check the renovation status of your stair.
https://archicad-talk.graphisoft.com/viewtopic.php?f=11&t=67572&p=301250&hilit=stair+layout#p301250
