Dorr Markers rotated 90 degrees
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-10-19
06:21 AM
- last edited on
‎2023-05-26
12:19 PM
by
Rubia Torres
‎2011-10-19
06:21 AM
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
AC26 MBP OS Ventura
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-10-19 04:15 PM
‎2011-10-19
04:15 PM
Dave:
I was able to reproduce this bug by mirroring a wall with a labeled door, using the Label Door-Marker 15. There is code in the label for Wall_Direction that I think is supposed to correct for this. The only solution I found was to change the Label Rotation value (Label Settings > Symbol Label > Rotation Angle) to 90.01Ëš (setting this to 90Ëš does not work correctly).
It would help if you named the Label you are using, as well as added screen shots of the problem.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-10-20 02:20 AM
‎2011-10-20
02:20 AM
Thanks, David.
I am using Label Door-Marker14. In my case, if I change the rotation to 270.01 degrees then it is correct. So that works but it's a little annoying.
Attached is a screen shot
AC26 MBP OS Ventura
AC26 MBP OS Ventura
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-10-20 03:16 PM
‎2011-10-20
03:16 PM
Dave:
I found this problem in plan, doors in walls running x axis are ok, doors in walls running y axis show the bug. Besides trying to correct the GDL code in the Label, I don't see a solution.
David
David
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-10-21 09:24 PM
‎2011-10-21
09:24 PM
I found that if I use the eye dropper/needle to transfer properties from a window label to the door label, then it corrects the door label.
AC26 MBP OS Ventura
AC26 MBP OS Ventura
