Eave attached to side edge of sloping roofs
Daniel_He
Hi, I created eave for a side edge of sloping roofs as showed in 1st picture, the problem showed in red circle, so I made a section to change angle of eave up to 15° as same as roof pitch as showed in 2nd picture. Then the eave and roof edge was aligned, however new issue appeared as showed in red circle mark in 3rd picture, how shall I do to solve it
Snipaste_2021-10-20_21-29-08.pngSnipaste_2021-10-20_21-34-04.pngSnipaste_2021-10-20_21-35-34.png
Daniel.He
ArchiCAD 25 3011 USA - Windows 11 Home 64x
DESKTOP 12600KF 64G RAM 3070 GPU
11 REPLIES 11
Daniel_He
Thanks guys for sharing solutions, it's so helpfu for a new learner
Daniel.He
Perhaps you are trying to solve the wrong problem?
To make the design look correct the return edge needs to be horizontal. Therefore you need to add a triangular roof element along that edge that connects with the main roof
Tim Ball
AC26, iMac
User since V5
