Exclamation Mark in Tabs not resolving (!)
Rene Pahlavan
The exclamation mark that appears when a view his changed from the saved view is not disappearing even after double-clicking the tab, and/or redefining with current settings. This is only happening in one view - the site plan, but I have tried saving new views with the same settings, and the exclamation mark won't go away. Anyone else having these issues?
AC27 (Apple Silicon)
macOS Sonoma 14.1.2.
MBP M3 Max (16-inch 2023)
Rene Pahlavan
I found a solution - I changed the View Setting - Zooming option to Fit to Window. This seems to have worked. No more exclamation in the tab finally.
Ivan Myers
I just had this same thing happen to me and I was pulling my hair out. My solution was the same but different.  I had modified one of my preset Dimension profiles in the Project Preferences, had to rename it, the new name of the Dimension profile was different and the View Preferences hadn't been updated to the new Dimension profile name.  Problem resolved.  Thanks for giving me a hint on the problem.
Designer/ Drafter
ArchiCAD 26 on 27" Mac
