Explode Into Current View, Turns Into Figure, No Vectors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-01-23 12:05 AM
- Place as External Drawing or Drag and Drop PDF
- Explode Into Current View seems to make it from a "Drawing" object to a "Figure" object, without creating any vectors
- Tried "not keeping the original elements after exploding"
- Renovation Filters has show "new items" turned on
- Also, tried exploding the Figure, but you get less options for pens and such
Any ideas?
AC 24, Mac
Thank you so much!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-23 07:04 AM
If it's PDF then make sure it has been generated by any CAD software so vector base info has been saved in it.
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-23 07:11 PM
Ohh! When you say that, it makes sense. Don't really have a way to know for sure if this file was made in a CAD program, it's a very complex site map from the surveyor so I assume it was done in CAD.
Pretty sure doesn't work like this in Illustrator, think Illustrator just finds the lines using processing power maybe. Remember doing this a decade ago in college, ha
I'm not seeing in the official Graphisoft documentation where it says that the file has to be made in CAD though, so I'm not 100% sure...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-23 08:06 PM
No, Illustrator doesn't just find the lines either. If what you see in a PDF is vector, both ARCHICAD and Illustrator bring in vectors. If, as seems the case with your PDF, the image is a bitmap, then it comes in as a bitmap. Illustrator does have a feature that lets you trace the bitmap to generator vectors...but the accuracy depends on the pixel density of the embedded bitmap image in the PDF.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-24 01:53 AM
Can we please update the official help guide from Graphisoft to include this vey important information. That is where I started and it seems like a very easy thing to note there, so I could have saved a lot of time knowing this was a factor. @GRAPHISOFT @Anonymous
https://help.graphisoft.com/AC/25/INT/_AC25_Help/070_Documentation/070_Documentation-98.htm
Also, it seems like Karl deleted this post maybe, I got a very confusing email notification, without providing any reason except that it was a duplicate. There is another very similar post, but it talks about renovation layers hiding new items, not my issue.
