Export to DWG overlapping items
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-10-06 10:27 AM
Hello Folks 🙂
I draw a multi-storeys building and I need to export it in dwg. When I visualize, for instance the second floor, and export it to dwg, the file I get shows all the elements underneath the selected floor I am exporting. So, while in Archicad, the floor plan is clean, in autocad, it shows the second floor overlapping the 3 floors below.
How can I do?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-10-06 10:21 PM
Files/interoperability/dwg dxf translators
Then import a new translator
Here import the xml file
Finaly use this dwg translator when you publish dwg file from the layout
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-10-06 10:29 PM
Ok I managed to use it but the result is the same. In autocad I visualize each floor with all the elements of the floors below that I shoudn't see. For example, all the walls and stairs which are under the slab and they shoudn't be visible. Now I have to go. Tomorrow I will send you a screeshot of what I am saying. And anyway thank you very much for your support! I really appreciate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-10-08 07:59 PM
I managed to solve the problem! I had to select each element on each floor and in "Floor Plan Display" select "Home Story Only". In this way I have a dwg drawing clean and tidy exactly the same I visualize in Archicad. Thanks anyway a lot for the support!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-10-08 09:18 PM
Of course Yes !
I did not think about this.
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
