Facades Walls with panels / profiles
Hi, I'm trying to figured out how to make properly profiles for facades walls - which they have a gabs or some 3D textures
- Profile manager it's seem that can do profile only : TopSurface and after this profile I can use it for FrontSurface - Not like SideSurface
- Also tried to do this troughs NISH window object - It's do very well but it not easy to change "parametrically" ( Also it's too many windows in the wall after )
- I tested also Texture and it do very well just it's so flat and any change is not exactly and reUplouding Libraries is little pain 😕
- Solid operations tools is also working but it's annoying work with it ( hiding layers ...)
Skärmavbild 2022-04-19 kl. 10.18.55.jpgSkärmavbild 2022-04-19 kl. 10.19.06.jpg
- Last what I know is using CurtainWalls but they are so heavy for projects and I want to combine  with windows and doors from the wall. this tool is not my favorit too
•  Is there something how to do it more simple or easier ?
• I'm looking for something solid operation tool but what it give me FrontSurface to profile my Walls
• Can I use it PARAOM for this ?
I hope you understand what I want is quite hard to explain 😇 I wanna do just Wall but with 3D texture and right now I will be very happy if I can do just some Lines / gabs in the walls but be able to applicate for whole house with possibilities to change dimension/positions of gabs
AC 7 - 27 SWE
iMac (Retina 5K, 27-inch, 2020),
3,6 GHz 10-Core intel Core i9, 64 GB 2667 MHz DDR4, AMD Radeon Pro 5700 XT 16 GB
11 REPLIES 11
ryejuan
Hi, you can refer to this topic it might help you. ðŸ˜Ž
https://community.Graphisoft.com/t5/What-s-new/split-face-on-exterior/m-p/326310/highlight/true#M918
In the end what is your Objective?
ArchiCAD 9 onwards
mija
i hope this helps, it is really easy to use.
Archicad 26, build 3001
Montenegro
Wau this is quite interesting solution thanks
AC 7 - 27 SWE
My free wall coverings do this.
Thank's. i
I'm not gonna lie it's little bit hard to navigate in your tools 😇
Unfortnately I have no Idea how it working 😕
AC 7 - 27 SWE
Lol I am aware, they are still being developed.
I will make a video soon.
can you rotate the orientation with this? or just purely horizontal? ðŸ¤”
ArchiCAD 9 onwards
It is purely horizontal.
It is just turning the wall into horizontal logs.
I see, interesting feature but not much control for the sizing of grooves, if you really intend to use it for groove lines. I think for me I will still prefer using complex profiles, but good to know. 😊
ArchiCAD 9 onwards
