Floor lines
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2021-11-13 05:44 PM
Hello All,
Beginner questions:
Attached are images.
Two floors have different composite spec but the top layer is the same. On plan it leads to a line (yellow circle), misleading for site crew.
How can we avoid this line? I have tried solid operation connect, it didn't work.
Thanking you
Kind Regards
pb
Macbook pro 13" /Big sur 11.4 + External 4K 27"
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-11-13 06:09 PM
In "Model View Options" under "CONSTRUCTION ELEMENT OPTIONS" change the "Slab" option to "Eliminate".
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
AC28 US/INT -> AC08
another Moderator
