Find the next step in your career as a Graphisoft Certified BIM Manager!
Function "edit module in another archicad"
Agence 88
Hello !
I don't know if other has the problem, but the "edit module in another archicad", which would be super useful while selecting an object in the 3D view, doesn't actually work when I click on it. Would be appreciated if anyone had a solution, or if Graphisoft could solve the issue. Thanks guys ! 🙂
julienK
Groups needs to be enabled  for this function to work.
From your screenshot only one column is selected.
4 REPLIES 4
Are you asking for a solution as a developer, or did you just post to the wrong forum?
julienK
Agence 88
Thanks julienK, it's awesome : yes with groups enabled it works well !
So this is not a programmation/technical issue.
Best,
Hello Barry Kelly ! Wasn't sure about the best forum, but julienK solved it. Thanks !
