Get rid of Lines. Plan view. Line delete. Merging same slab. Way line put pieces together.
aryastark
How CAN i get rid of this same elements lines?
i want to merge them but not working.
They are slab.
And they are SAME. with WHOLE values. But there are lines at the combination area.
How can i merge them together to evade this lines?
valar morghulis.
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
In the Model View Options have a look at the Construction Element Options.
There you will see some options for the slabs.
The lines can be hidden but only if your slab surfaces are the same level and the same material.
aryastark
wohooo worked!1!! thank you.
Ver: AC23
Memory: 16384MB RAM
Guru
Fancy. AC24 has been released and I have only just learnt of a feature added in AC23...
