2005-05-19 10:30 PM - last edited on 2023-05-23 05:20 PM by Rubia Torres
2005-05-20 03:24 AM
johncassel wrote:Are you using a PLA library or do you have an expanded library so you can edit and add objects.
Each time I adjust an object in a Section Elevation View I refresh the image to see the effect of the change. This takes a few seconds.
I do have the Section/Elevation set to show Vectorial 3D Hatching so that the fills of the materials show up.
I have a fairly quick computer and a fairly quick graphics card--both with a good deal of memory.
How can the 2D Section Elevation Refresh be speeded up?
Thank you,
John
2005-05-20 07:03 AM
johncassel wrote:Use limited depth S/E so that the whole model does not have to be re-calculated. Also, do the Layer sets where the interior stuff is turned off for the elevations.
2005-05-20 08:38 PM
Djordje wrote:Djordje,
2005-05-20 10:05 PM
2005-05-23 06:40 PM
