How to select fills with same color?
cokashi232
I need to export shadows from Archicad to dwg. So I set the shadows, then exported the file into Archicad 2D lines. When I open this last file I have lines and fillings for every surface, but I need to select only those of the shadows (which have a specific color). I tried with the find and select tool but I can’t find an option to select same fill color, any help?? Thanks
Actually. If you first select Fill as Element Type you can then choose Fill Background Pen and Fill Foreground Pen specifically.
