Read more
How to view objects below ground level
So I am using the 'sea level' for my basement plans. It has walls, stairs, etc...
The problem is, they don't show up at all in 3D view - how can I change this so I can view everything in 3D?
I did it once before but I can't seem to remember how I did that... CAD block...
Thanks
5 REPLIES 5
David Maudlin
kiwistudent:
Check the Filter Elements in 3D dialog box, it might be excluding your basement story.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
It is set on 'Infinite' in the filter dialogue box, though I did try from basement to roof, didn't make a difference.
Have you tried going to 3D mode via an elevation?
David Maudlin
kiwistudent:
You can also try right-click and select "Show All in 3D", or see if you have a 3D Cutting Plane and 3D Cutaway is checked.
Make the ground material glass ?
