How unlock and unhide all elements and layers
Bread_Chan
i would like show elements by schedule , however , after trying unlock , show all functions , i still cannot select elements on schedule , please help , thanks
aarkell
With that schedule open, have you tried opening the layers dialogue box and unlocking and showing all layers (i.e. all visible and unlocked). That should at least make your cells editable. If you want to use the 2D and 3D select buttons, the two at the top of your screenshot, you'll want to make sure your 3D view also has all layers visible and unlocked, or at the very least the layers that your scheduled elements are on should be visible and unlocked.
Andrew Arkell
AC 18-27 USA 4060
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 10
1 REPLY 1
aarkell
Andrew Arkell
AC 18-27 USA 4060
Setup info provided by author
