Read more
I want to erase the lines on both sides of the last step of the stairs.
LeeJaeYoung
This question is a result of the previous answer.
Solved: Re: Why is there a stair finish in CORE ONLY? - Graphisoft Community
Q1. I want to hide the two lines with red circles on the stairs.
Q2.  I want to move the character 4R x .... and 3G x .....
What should I do?
1. My guess is that when Ends at Second Last Tread is set, the positions of "DN" & "4R x" & "3G x" should be auto-corrected, but it doesn't.
AC27 on window 11
Yves
Q1 :
 Or
Q2 :
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Yves
Q1 :
 Or
Q2 :
Yves Houssier
Belgium
Archicad 19 -> 24
iMac - Mac Os 10,13
Thank you for answer.
I want to create a hidden line with a red circle.
What should I do?
Do I have to draw with a line?
AC27 on window 11
