I want to make the color of the wall of the section and the site different.
LeeJaeYoung
What should I do?
I changed the surface to white, but nothing happens.
AC27 on window 11
Check the Filter & Cut Elements in 3D settings.
You probably have 'Cute Surface Display' set to 'Custom' so all cut surfaces look the same.
LeeJaeYoung
You are the source of strength that keeps me studying ArchiCAD. ^^
AC27 on window 11
