INFO BOX SLIDER...
Llian
How do I bring the slider back into the INFO Box without opening the setting dialog?
Lilian Seow
LEED AP | cSBA
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
Assuming then your info box is across the top of your screen.
Grab the bottom border and stretch it down a bit and you should see a thin slider bar.
But there should be no need if you have a wheel on your mouse.
Just place cursor over the infobox and scroll the wheel.
5 REPLIES 5
Silly question, but what is a slider in the info box?
Llian
To scroll left to right and vs….
Lilian Seow
LEED AP | cSBA
Llian
Thanks Barry! the wheel works!
Lilian Seow
LEED AP | cSBA
Here is a clip showing how this works (this was a new feature introduced in AC20):
