Find the next step in your career as a Graphisoft Certified BIM Manager!
Keep Solid Element Operation Open by default?
FCA
Is there a way to keep Solid Element Operation Window open by default? Every file requires me to open it from fresh even though I use it everyday.
What is the reason for this? Am I doing something wrong?
Rubia Torres
Hi @FCA,
You can set it in your work environment settings to appear in the toolbar. Easily you can open it while working:
Step 1 - Add the Solid Element Operations command to your toolbarStep 1 - Add the Solid Element Operations command to your toolbarStep 2 - Just click on the SEO icon to open the dialogStep 2 - Just click on the SEO icon to open the dialog
Best,
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
Rubia Torres
Hi @FCA,
Best,
Rubia Torres
FCA
Great, thanks so much!
BJC
Or you can assign a keyboard shortcut. I use Control O.
