Layer Combination - Wall cleanup
OBERMEYER
Walls clean up fine in a view but when we change to a new layer combination in the same view they no longer clean up. No other changes, just viewing a plan, open layer setting, and switch from one combination to another. That's all. We're not changing any other setting. Any suggestions. Bug?
Andrew Obermeyer | Architect
OBERMEYER Architecture
www.obermeyer.la
AC 26 Mac M1
OBERMEYER
Got it. We were not setting up the wall clean priority setting in the new layer combination. Some layers were set to 0.
www.obermeyer.la
AC 26 Mac M1
Lingwisyer
Guru
If you need to modify multiple layers in multiple layer combinations, you can do so via the Attribute Manager.
Ling.
