Read more
Layers visibilities inArchicad 26
GaborV
I don't know what is happening, help me! I'm setting it so that all layers are visible. I select a layer, then delete it. I close the adjustment window. When I open it again, some layers are set to visible, some layers are locked.
No layers combinations are set, no stapled layers are set. What happens?
AC 4.5-26
i9-9820X | 64 GB RAM | Windows 11 Pro
if you import layers from older Archicad in xml, it happens. It always worked for me, but I can't make a video of it. If I delete the imported layerss, create new ones and delete them, the imported xml setting still comes up.
AC 4.5-26
I just tried what you said and all layers remain on and unlocked.
Could you maybe record a short video to post here to show what is happening?
AC 4.5-26
