Find the next step in your career as a Graphisoft Certified BIM Manager!
Library Part Maker - Boolean Subtraction does not work
gdford
- I have made an object with the Library Part Maker
- The blue part of the object is made with a column that has a High Building Intersection Value.
- The slab that the object is sitting on has a Low Building Intersection Value.
- I assumed the automatic cutting that happens with the column and the slab would continue after the library part was made.
- but apparently not
- is there anyway to do this with the Library Part Maker??
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
Objects can not interact this way.  Once the object is created it's no longer going to behave like the base tools.
gdford
hummm -  from a tool design standpoint, that is a shame.
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Convert them to Morphs maybe before saving them as Library Parts?
