Read more
Main file size Bloated after Hotlinking a File
astonyap
Hi all,
My main file size increases tremendously from 14mb to 200mb whenever i hotlink this particular file.
This does not happen when i hotlink any other files to my main file.
PS: Main file is an empty file that is used to hotlink other files into 1 file
Main file size: 14mb
Hotlink File size: 99mb
It does not make sense that after linking the hotlink file to the main file, the main file size increases to 200mb
I have tried converting the hotlink file to be a MOD file and hotlink that instead but the same issue occurs. Have also tried Archicad's Open and Repair option but the issue persists.
Could anyone shed some light on this problem?
If you would like to take a look at the main file and hotlink file, i have uploaded them here:
Main File - https://drive.google.com/file/d/1xt1VtpRIWqRYjEjSMmQ7fdI-SVaUTSwN/view?usp=sharing
Hotlink File - https://drive.google.com/file/d/1vTwhRXgF2JpunLlnFEyQAlROLtZMKXGJ/view?usp=sharing
Any help would be greatly appreciated
Aston
EDIT:
i have tried re-doing another file with the same curtain wall setings and size and i get the same problem, with my main file size increasing by a lot. Could it be a curtain wall bug/ issue?
Noemi Balogh
Hi Aston,
Please check these articles:
Archicad 25 sudden file size increase
How to optimize a project's file size
How to Optimize Your Project Performance
If none of these helps, and you believe that narrowing the issue down to curtain walls is the issue, I suggest to contact your local support representative for further help. They will be able to handle this issue correctly and check if it's a bug with the tool or a setting is problematic in your case.
Kind regards,
Noémi
Noémi Balogh
Community Expert, Admin
Karl Frost
I'm thinking it is somehow related to the curtain wall geometry but not sure how.
re article Archicad 25 sudden file size increase
This is about build 3002 and I'm using build 4013 so should not apply.
Other likely culprits:
Libraries - not an issue here as only minor items
Attributes - look pretty straightforward, certainly nothing to create this size blowout
Other external content - none
The curtain wall geometry is pretty intense (poly count 540K) but it's the same for the hotlink file and the main file plus hotlink so no extra geometry is being created.
As per Noémi's advice try your local rep - this might have to be sent up the chain for serious testing
