Make Side hung window open 180°
Malinski
Hi 🙂
This seems pretty simple but I can't find the parameter for it.
Why are side hung windows limited to 90 degree angle opening?
I'm trying to open them 180 degrees for visualization in a ventilation subject.
Am I missing something?
I don't use Graphisoft windows, but I assume it would be because most windows would recessed into a wall - there will usually be a reveal on the outside.
So a sash hinged at the side of the window will only be able to open up to 90°.
That is not to say that centre sashes or non-recessed windows shouldn't be able to open to 180°.
Of course that will also depend on the manufacturer of the window.
But we should have the choice so we can accommodate all situations that might be possible.
I would like to see a plan view of your window in the wall just out of curiosity.
vistasp
I've used such windows too on a number of occasions. Luckily, I don't usually show windows open in plan or 3D, so haven't been too bothered by the 90° limitation of the GS windows. However, it does seem that the option should exist.
I would vote for it, if you make a wish, @Malinski
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Barry, out here we use wide-throw hinges (which we call Parliament hinges for some reason) so that the shutter can flatten against the wall despite there being a reveal.
(Image below, taken from the net)
= v i s t a s p =
bT Square Peg
