Measuring measured items don't agree
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-01-25 05:05 AM
I measured between wall - then I measured the measurement
AND they are 1" different???? HELP Please as this is not a good start
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-25 05:06 AM
I did make sure that I had no fractions in my setup.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-25 05:53 AM
Are you trying to compare between the background CAD file and Archicad drawn elements? Is the background file is image or CAD file attached as Xref?
AC 09-27 | INT | WIN11 64
Dell Inspiron 7591, Core i9, 9880H 2.30GHz, 16.0GB, NVidia GeForce GTX1650, 4.0GB, SSD Internal 500GB, Dell SSD External 250GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-25 06:53 AM
NO
The background is there but I am comparing two dimensions.
The first string is snapped ot the walls placed in Archicad
The 2nd wall measures the string of dimensions.
The 2nd string of dimensions add up to 1" more that the measurement from the start to the finish of the first string
This happens on all my long strings of dimensions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-25 10:33 AM
Change your dimension settings to show as much decimal accuracy as you can.
You will probably find the walls are each a fraction less than they show - so they will be rounding up to the values you see due to your settings.
But when measuring the overall, there are enough fractional errors to make that one dimension round down to what you see.
i.e. 10' 1¾" will round up to 10' 2"
But 10' 1¾" + 10' 1¾" + 10' 1¾" will round down to 30' 5" (actually 30' 5¼").
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-26 08:37 PM
This is clearly due to rounding error. Best practice is to input walls and other entities based on exact dimensions, rather than relying on a dimension display. (What is displaying in the tracker may be 1'-4", when you are actually drawing 1'-3 5/8" because you've turned on display fractions to the nearest inch, say.)
AC26 (since AC6.0), Win10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-26 08:51 PM
Yes, the items are drawn real but only need nominal dimensions to layout walls. Plus this is an existing building. Struggling to make this work easily without fractions as they are of no benefit. Nominal dimensions are perfect for the plan with actual perfect for the detail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-26 09:03 PM
Accuracy is always a benefit. Giving contractors unachievable accuracy in dimensions is not. However, in laying out walls, any decent contractor should be able to build to at least the nearest 1/2" without breaking a sweat.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-01-26 09:22 PM
We always dimension to one side of the wall. To snap a chaulk line only requires one. And I measure to the same side of a wall unless there is that rarity where a fraction of an inch would cause an issue.
Then it avoids anyone from adding and subTracking fractions on a job.
I remember the days when I’d find a good contractor or staff who struggled or could not read.
But just simpler to layout without fractions.
