Modeling Hip Roof Truss Pacakge
Jefferson
Increasingly I am finding a need to model hip roof truss package. Currently my methodology, [that felt like a George Bush word], is to model the common trusses using Objective, then dive into the painfully complex method of modeling individual trusses, opposing ends.
In a typical residential hip roof truss package the last 8 to 12 feet 90° to the common trusses with bottom chords in hangers off a girder truss, [same profile as the commons.] As the roof "walks" around corners, inside or out, the complexity gets exponentially more complex. [see screen shots]
There has got to be a better way!!, and I'm hoping someone has been here before and can offer up some advice on a better way I'd be very appreciative!
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
1 REPLY 1
vfrontiers
Just ran across this post... I happened to be the guy that created the TRUSS PRO series for Graphisoft about a hundred years ago!!!
Since then, I've dovetailed them into TRUSS RUN and HIP SET...
Direct message me if you think they will help...
Duane
Visual Frontiers
AC25 :|: AC26 :|: Enscape3.4:|:TwinMotion
DellXPS 4.7ghz i7:|: 8gb GPU 1070ti
