Morph Tool - Pull / Push bug (AC16 SWE) ?
Hi!
Before I have tried AC 16 INT version, what I can remember from that version is that :
- I could choose a face on my morph, then choose Push or pull and enter the value (x, y, r or z) I want to push or pull from original face and the face was pushed that value. Is this true?
In the Swedish version of AC16, it's totally impossible to push or pull with an correct value, it's always total random and because of that the Morph tool is totally useless right now. Or do I make some big misstake now that I don't do when I run the INT version?
Are you using the Tracker or the Co-ordinate palette?
I think it works best with the tracker and should work as you describe.
Barry
Without notice, the tracker had been turned off. Everything else does work without tracker (and work like we did before tracker was introduced).
But now, with tracker turned on, it works. Thanks!
