2022-03-20 08:30 PM
2022-03-21 04:14 PM - edited 2022-03-21 04:20 PM
Hi, nice project you have here! The project seems to be quite integrated volumetrically speaking.
If the buildings were more detached or more clearly diferentiated i would defintely suggest going the hotlink way. But same as Karl, i not sure here.
Question: do you need to present each part of the complex as a separate building? i ask it because the floor level diferences you mention is actually not that much, and levels seems to align more or less well (but yeah, what would be the ground floor of the taller wing would actually 1st floor relative to the lower parts).
So, If you dont need to present diferent parts of the complex as diferent buildings, i would try doing it as a single file woking with some main levels (but not a floor level for each different slab). And maybe only the detached semi buried building as a hotlink.
And now we are at it, Graphisoft, please, let us, the people, manage attributes in a centralized way!
2022-03-27 05:34 PM - last edited on 2022-03-31 04:38 PM by Karl Ottenstein
Thank you very much for the feedback,
the jpg image i uploaded at the main post was an example close to what i was thinking and not exactly what i am going to do (answering the connected buildings you mentioned, the buildings will not be connected). The solution will looks like the image i attach on this reply. So to clarify what i am thinking to do at the moment (which im not considering 100% as the best solution) is that: i'll start and finish one of the four buildings ( 1 of 4 ) with a well organized template. Then i am going to create a PLN with only the plot and its mesh, and some 2d information i need (building lines, points etc.) after that i am going to import the 1st building's pln into my main plots pln, then create a separate pln for every other building etc. My problem is that, i would like somehow to see the main plot in every building's separate pln (and not only the other way around) in order to adjust the building according to plot's heigh in every position. Is this possible or should i create the plot in every pln or even create a new module of the plot, import it in every building's pnl and after that manage to hide it in the MAIN Plot's pln fine, which will be my master plan? My main goal on this project is to create architectural plan's in every building separately and after that, to go in the main PLN and export a master plan and some general sections.
2022-03-28 03:11 AM
I am not a hotlink master, but my understanding is this.
Create your 4 buildings in separate PLN.
Create the site in another.
You hotlink the buildings into your site PLN.
You can also hotlink your site back to the 4 building files, but you have an option to ignore nested hotlinks.
That way you do not link the buildings back to each other - you are effectively just linking the site back.
I hope that is correct.
