Object Display - Different Plans
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2004-07-17
11:59 PM
‎2023-05-23
05:26 PM
Rubia Torres
I typically have object settings displayed as a solid line on the Floor Plan; if I change settings to dashed line, the object is dashed on both plans. I have changed Display Options to both Construction and Construction RCP but no change in display. I have looked at story settings, but didn't find anything to help me.
Thanks, in advance,
Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-07-18 01:25 AM
You can play around with a master GDL and global variable to accomplish this but I don't recommend it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-07-18 02:07 AM
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-07-18 01:43 PM
See:
Reflected Ceiling Mode for Plan Window
and
The New Working Environment
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-07-20 08:27 PM
ELL wrote:The object can (easily?) be scripted so that, if its elevation to the current storey is more than whatever you specify, the linetype changes to dashed ot whatever you specify. So it is realy a matter of scripting the lamps, curtain rods and other stuff that belongs to the upper echelons to display properly.
Seems like with all of AC's modeling ability, it would automatically identify the object's elevation and create different line types depending upon the Floor Plan cutting plane.
Any GDL guru likes to help us out here?
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2004-07-20 08:40 PM
The sensitivity to elevation would be, for example, that a beam could tell that it is overhead in the floor plan and show as dashed, but would display with solid lines in RCP. Alternatively one might wish to have furniture show as dashed in a ceiling lighting plan. The elements would not be responding to a change in elevation but to a change in view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2021-11-30 10:06 AM
There is method to script object to look different on different stories. Check object Downspout Complex 25 from default Archicad 25 library
You can also add script changing the plan view according to MVO Lighting and HVAC Floor Plan Symbol, or add your own MVO settings. This way you can have absolute control over object view on plan according to story and type of plan. Sounds complicated but it is not.
