Plan views
I have a complex building with several floors.
I have a challenge in the 2D plan view:
When I move up in in my plan view, I want to see everything that is below the cut. So, for example, when I open the plan view for 4th floor, I want to see everything below (except where the view is blocked by elements such as slabs etc).
For instance in the plan view of the roof I want to see all environment between the buildings - but this doesn`t accur now.
Is there any other way to do it, besides making multiple 3D-documents with parallel projections? So that I can still use my plan views... Suggestions?
Best regards,
Bjarte Stav
1 REPLY 1
Dwight
There is a degree of control over element visibility between stories.
See the element dialog "Floor Plan Display" for the choices available for each type.
Dwight Atkinson
