Read more
Portal Frame
Can anyone tell me how I make this portal frame using a object from the library. I have found the portal frame objects but cannot find a way to make the object with 2 slopes where th eridge is offset from the center.
What Im really looking for is a portal fram objecvt that I can change the slope angle and ridge position. Any help much appreciated!
Lisa
1 REPLY 1
David Maudlin
Lisa:
In the US Library (I don't know about the French Library), there is an object Lean-to 12 that is one half of the Double Slope 12 object. Perhaps you could pair two of these objects and change their parameters to place the ridge where you want it.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
