2022-11-02 05:27 PM - last edited on 2023-05-09 02:01 PM by Rubia Torres
I have an existing wall joining a new wall and for the life of me I cant get them to show in plan properly. The attached image is what keeps showing.
What is the trick?
Thanks
2022-11-02 10:14 PM
Hi Ivan,
for me it looks that you might have two things happening here:
Best
Karol
2023-03-25 09:15 PM
Thanks for the reply. And sorry for my late reply. I ended up using a masking fill and called it good.
It seems walls often join improperly when not at 90 degrees. But thanks anyway.
2023-03-26 06:16 AM
It should only be a problem when there are more than 2 walls involved (they can be in hidden layers as I suspect in the image you show).
Usually with more walls involved it can be solved with the junction order or by moving the reference lines around so they do/don't touch other walls.
