Read more
Railing Overrides
All, i am finding it very frustrating to find specific overrides that apply to railing parts specifically. The image attached shows the panel and fixings to be white only, and i feel like have tried everything from material changes to MVO. The only progress i can make is changing the MVO to Simple and applying a material to the rectangle that represents the glass, but i don't understand why i can't control the 'white' panel from anywhere else. Is it elevation settings, railing settings, MVO, GO, surfaces, materials or what!?
HELP PLEASE!
1 REPLY 1
Ok, finally solved this. I noticed that the white only appears when on Existing Renovation Status, and not on Proposed [even though it was listed as existing on both]. If i edit the railing, some of the elements were listed as new for some reason, and wouldn't change. Despite switching the whole thing to new and back it didn't change.
To solve it I had to demolish it, and switch back to existing. Seems fine now on both existing and new views.
