Railing Tool-Custom Inner Post is not interrupting rails
rgarand
I have developed a custom inner post that has a 2" void in the center. The intermediate and bottom rails continue through the custom inner post. Does anyone know of a way to interrupt the rails? I looked at making a custom panel, but that is not available.
Robert J. Garand
ArchiCAD USA 27-Build 5001 USA FULL
Windows 10 Prof (64 bit) - Intel i9-10920X CPU 3.50 GHz - 128 GB RAM - NVIDIA Quadro RTX 5000
2 ACCEPTED SOLUTIONS
Hello @rgarand,
Did you try to use SEO ?
I use to ajust my railing modelisations by this way.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Yes.
Just go into edit mode for the railing and SEO the elements you want.
You may need to use subtract upwards/downwards seeing as your post has a void in the middle.
4 REPLIES 4
Hello @rgarand,
Christophe - FRANCE
An SEO within the Custom Post Object?
Robert J. Garand
Yes.
Ahhh excellent...and when you pick one Inner Post they are all selected. This worked great, thank you. Screenshot 2023-03-29 090400.jpg
Robert J. Garand
