Railing axis rotation
RVS
Hi, prodigies,
Does anyone have an idea how to rotate the railing along the reference line (similar to beam axis rotation)? I've combined the snow barrier using the railing tool, which works okay until I need to modify the inclination to adjust to the roof object.
Does anybody know a better and more efficient way how to model similar roof components?
Romas
5 REPLIES 5
Hero
Railing Settings => Railing => Segment => Segment Settings => Segment Slanting
Win10 | R5 2600 | 16GB | GTX1660
Thanks,
The Segment looks slanted, but the custom inner and node posts (created as a Railing post object) are still vertical. Generic posts work okay.
runxel
If you know a tiny bit of GDL you could script your own railing post.
You'll need to derive the slanting angle however by yourself. It is given implicitly through a vector stored in the global "RAILINGPOST_TOP_COORD".
With a tiny bit of trigonometry the angle is easy to get and can be forwarded to a "ROTY" command:
tri_a = RAILINGPOST_TOP_COORD[1]
tri_b = RAILINGPOST_TOP_COORD[3]
tri_c = sqr(tri_a^2 + tri_b^2)
alpha = acs((tri_b^2 + tri_c^2 - tri_a^2)/(2*tri_b*tri_c))
roty alpha
!/*.... your geometry comes here */!
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
RVS
Hi, to be honest, programming and GDL scripting is not my area
Do I need to add this code to the 3D tab?
Yes, this would come into the 3D script. But if you're not familiar with coding in GDL it might be a bit hard to do everything correctly 😕
