‎2003-12-02 08:12 PM
‎2003-12-02 10:00 PM
‎2003-12-02 10:24 PM
‎2003-12-02 11:08 PM
‎2003-12-03 06:26 AM
BryanRichards wrote:You can get vectorial shading as David advised.
Im trying to edit the sections im creating. Can i shade or even better , render my sections?? .. I say sections, but the renders would be more appropriate on my elevations. How do i create these or will i only get hidden line sections?
‎2005-05-16 09:39 PM
Djordje wrote:When I try this method, the pasted elements have different colors than my 3d window. Is there some setting to make them show as the same?
Use setion tool in 3D, copy the construction elements polygons over to the Section/Elevation window.
‎2005-05-16 11:31 PM
‎2005-05-17 05:04 AM
Mark wrote:you need to enable it in your work environment profile. the good news is that it doesn't have to take up any more space along the menu bar because you can put where you like: i have it as a sub-menu of the 'Extras' menu.
How do you get to the special menu in 9.0?
‎2005-05-17 05:43 AM
‎2005-05-17 05:51 AM
