Read more
Renovation filter & wall types
Tom Krowka
Am using a non-composite wall type (just empty fill with an arbitrary width in the dialogue box). When the override filter is set to solid fill and the settings are correct, the wall shows up as empty fill, but is filled wherever there is a door opening.
Can anybody else duplicate this or am I missing a setting someplace. It works fine with a composite wall.
Thanks.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
5 REPLIES 5
Does the door have a masking fill turned on?
Tom Krowka
It did, turned it off, so took care of the door part of the problem. The other part of the problem (wall not filled in per the override) is not resolved however. I could turn on the fill in the empty fill (it's now set at window background) but that would mean the override does nothing to this type of wall.
Thomas@wkarchwk.com
www.walshkrowka.com
Dennis Lee
I think if the background fill pen is the "window background color", then the override won't work. This can be a useful feature too, but it is confusing. Try setting the pens to a white pen instead in the wall settings.
Also, I think if the cut fill is one of the "solid" fills, the renovation feature won't do anything to override them.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
David Maudlin
Yes, see this thread:
Renovation Filter Overrides on Solid Fill Walls
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Tom Krowka
Thanks for the heads up. Will work it out.
Tom
Thomas@wkarchwk.com
www.walshkrowka.com
