To understand better what Eduardo is suggesting, see this identical/old topic - which is pre Morph and so uses the wall tool, but same solutions.
http://archicad-talk.graphisoft.com/viewtopic.php?t=292
Rather than a Morph or wall, if the screens on the porch have frames like windows... then use a Window object in a wall and set the glass material for the window to the described surface. Then, you can schedule the screens with elevation previews etc, too.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
