Section fills suddenly disappear while I edit the drawing. AC28
alessiofazzi
Hello anyone have a solution for this issue? Out of the blue the fills of the section disappear, to get the fills back i have redraw and regenerate the view (Ctlr+Alt+Shift+R) but when edit or move an object the fills disappear again. This beaviour started while working on the section, before all was fine and suddenly this Happened. Closing and reopening the file didn't help.
1 REPLY 1
Did you activate a View that has a Graphic Override stored in it?
So, when you activated the View, the Graphic Override became active and hid all cut fills?
Setup info provided by author
