Read more
Slab cut fills and cut lines not showing in plan
I am having trouble getting slabs to show cut lines and cut fills in plan, for some reason they are showing uncut lines instead. All walls are showing cut lines and fills, but not slabs. I am working in Archicad 17, and the cutting plane is definitely cutting through the slab.
Any ideas? Could this be a simple setting I have wrong?
Jake
1 REPLY 1
Eduardo Rolon
Slabs are never shown in cut in plan and for architectural drawings that is not standard procedure. The easiest way to show it is to convert them to Morphs.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
