Slab (transparent)
Eman
Is it possible to make a concrete slab transparent, so I can see through it?
Thanks.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
Eduardo Rolon
Put it on a layer that is setup to wireframe for 2D or change the BMat to glass, or do both.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
7 REPLIES 7
Eduardo Rolon
AC28 US/INT -> AC08
another Moderator
Eman
Yes good idea I changed it to blue glass and it is what I want.
But I still want to know how to put it on a layer that is setup to wireframe for 2D!
ejrolon wrote:
Put it on a layer that is setup to wireframe for 2D.....
Eman / Draftsman
Eduardo Rolon
Change the following icon for the layer and the slab will be wireframe in sections and elevations
AC28 US/INT -> AC08
another Moderator
Eman
Hi Ejrolon,
I prefer changing the BMat to glass because I can see it in 3D, because wireframe is only for 2D.
Thanks very much for the help.
Eman / Draftsman
I don't think so
Wireframe is for 2d and 3D
or...
You can create a Graphic Override too 😉
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
Eman
OK thats good!
Please can you tell me how to create a Graphic Override?
Thanks
Eman / Draftsman
Guru
https://helpcenter.graphisoft.com/user-guide/65466/
