Read more
Smooth edges in curved complex profile
I've created a complex profile with a radius on it. How can I "smooth" that line out? So it doesn't appear in my elevations.
Erwin Edel
I think you can only 'hide' edges on morphs. If it is just a simple shape, you could convert it to a morph. If you are using complex profile to show different building materials assembled together (show a bit of detail in section), you might want to mask the line in elevation / section with a fill or a white line with the same thickness.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Carstenem
use the shell tool.
- draw the shell in floor plan
- view in elevation
- select shell , click on arc, choose point on pop up , now shell is flat
- click and add the needed polygons and create your profile
- change shell thickness to suit
Done ! See attached Illustration for visual guidance
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
