Read more
Some lines from object missing in elevation
Hello, I've got this elevation that is not showing up correctly. As you can see in the picture some of the lines from the railing are missing. The model is built from modules and every fourth window is one module. There are three different types of modules and they are placed next to each other (not mirrored or anything) on story 1, story 2-4 and story 5.
The railing is an object but as the missing lines appears slightly and random I guess that the thing I am missing is in some sort of view or in the elevation option?
1 REPLY 1
The problem was solved when I moved the elevation on plan further away from the building.
