Read more
Stair description - how to change units and text?
JelenaKujundzic
does anyone know how to change description in stairs in archicad 21?
Archicad automaticaly writes number of "Risers" and dimensions in inches.
i would like to change it into my language and that it writes dimensions in cm or meters.
Thank you
JelenaKujundzic
Yes,thats it.Thank you so much
And about the text-it is also in that section, I just type in what I want it to say.
Thank you
I am not sure about the language but what the description contains and the units are all controlled in the stair settings.
JelenaKujundzic
Thank you
